Hi guys, I have been using uccnc on my mill successfully for about a year now, I run it through a UC300 usb board on windows 10, and everything is good. I also have an old XP pc which I use to run my denford orac lathe and it's running via a parallel port.
Recently the old XP pc has began to fail, so I thought it was time for an upgrade ! Last week I purchased a UC100 controller, to get rid of the parallel cable. I then took my wife's house pc out to the garage, to set everything up, and all went fine, I had it running machturn in no time at all, with the UC100 controlling it, it was way smoother running than it's ever been
Then my wife decided she wanted her pc back, so I thought, no problem, I'll just plug the UC100 into my mill pc, and although I know I'll never use both controllers at the same time, I plugged the usb cable into my pc. This is where the problem arises ! When I want to run my lathe, using the UC100 (non licensed) and machturn, there is no problem at all, but when I want to go back to my mill, even though I have a valid license, I can't get UCCNC to start in anything other than demo mode (it can obviously detect both controllers) If I simply unplug the UC100 controller everything is fine. It's not a huge problem to put another computer in the garage so I can run them both seperately, but it would be nice if I could get them both to run from the same pc ? Just wondering if there's some kind of workaround.
