vfd stopped connecting after power cut
Postby kevanmorcom » Tue Apr 15, 2025 5:29 pm
Good evening guys and girls
Looking for help from some of the smart people in the hive, I've been running UCCNC for 12/18 months without any problems until last month when we had a power and now I can't connect UCCNC to the VFD. I have reset the and tried every setting under the sun but cannot get them to talk to each other, I can get the VFD to run the spindle via the front panel of VFD but not via UCCNC. The only settings I cannot find are the spindle settings for the port and pins in UCCNC I can only think that is where the problem lies, Does anyone have any spindle settings I can try please.
kevanmorcom
Re: vfd stopped connecting after power cut
Postby cncdrive » Tue Apr 15, 2025 8:13 pm
Which motion controller are you using?
How are you controling the VFD?
Postby kevanmorcom » Wed Apr 16, 2025 10:18 am
hi sorry completely forgot that part, Huanyang 220v 2.2kw using Dans HYPLUGIN and a UC400ETH and UCCNC software which has worked faultless until power cut, all i get now is a message saying VFD not responding do you want to continue.
kevanmorcom
Postby cncdrive » Wed Apr 16, 2025 9:41 pm
So, you using a Modbus device, is that working?
I think the only way to debug this is to measure on the RS485 modbus lines.
Postby worrisomewallow » Thu Apr 17, 2025 8:33 am
- What type of VFD are you using?
- What kind of breakout board or motion controller do you have?
- Are you controlling the spindle via analog, PWM, or RS485?
worrisomewallow
Postby kevanmorcom » Thu Apr 17, 2025 5:53 pm
Thanks for you reply, not sure if i have done this right but i seem to be getting a reading of 7v out of modbus, does that sound about right.
kevanmorcom
Postby kevanmorcom » Fri Apr 18, 2025 3:23 pm
worrisomewallow wrote:- What type of VFD are you using?
hi
I'm using Uc400eth with Huanyang 220v 2.2kw using Dans HYPLUGIN RS485
kevanmorcom
Users browsing this forum: Google [Bot] and 8 guests
