Macros
Macros
Postby Phil1322 » Mon Mar 31, 2025 3:57 pm
Hello,
I'm very new, not just to Macros, but CNC generally. I want to start off with quite a "simple" Macro to test out my port 1 pin 1 and toggle it on/off 5 times, with a delay in between This is the code I've done
M101.txt
(188 Bytes) Downloaded 102 times
I'm using UCCNC (V1.2113) with UC300 5ltp ETh and a UCBB
Errorlog.txt
(935 Bytes) Downloaded 97 times
Eventually, I want to create a pretty complex (for me) Macro for my ATC Spindle, but I want to understand Macros better before I do anything. if I can't get my head around this "simple" Macro, what chance do I have! lol
Regards,
Phil
Phil1322
Re: Macros
Postby ger21 » Mon Mar 31, 2025 4:14 pm
I think you want something like this. It's in C#
; Macro to toggle Output 1 (Port 1) 5 times
int LOOP_COUNT = 0;
while (LOOP_COUNT < 5)
  exec.Setoutpin(1,1);
  exec.code "G4 P0.5";
  exec.Clroutpin(1,1);
  LOOP_COUNT++;
Re: Macros
Postby ger21 » Mon Mar 31, 2025 4:16 pm
Take a look at the default M6 macro to see how a macro is written.
Re: Macros
Postby Phil1322 » Mon Mar 31, 2025 7:08 pm
Thank you Ger21, I will be able to test this tomorrow
Cheers,
Phil
Phil1322
Re: Macros
Postby Phil1322 » Tue Apr 01, 2025 2:45 pm
I've just tried the Macro and I get the following Errorlog
Errorlog.txt
(699 Bytes) Downloaded 86 times
The Errorlog is just as confusing as the Macro :lol:
I just copied the text, pasted it into Notepad, saved it as M101, and then placed it inside the Macro Folder in the UCCNC Profile Folder (is this correct? Is there anything else I've missed or need to do?).
Phil1322
Re: Macros
Postby ger21 » Tue Apr 01, 2025 4:32 pm
Change the first line to this:
// Macro to toggle Output 1 (Port 1) 5 times
Re: Macros
Postby Phil1322 » Tue Apr 01, 2025 5:16 pm
I've just tried that and still no luck, here's the new error log
Errorlog.txt
(306 Bytes) Downloaded 89 times
There are fewer errors, so I guess we're narrowing it down...?
Phil1322
Re: Macros
Postby ger21 » Tue Apr 01, 2025 5:35 pm
One more time. Sorry, I'm not a programmer, and was going by memory.
int LOOP_COUNT = 0;
  exec.code ("G4 P0.5");
  LOOP_COUNT++;
Re: Macros
Postby Phil1322 » Tue Apr 01, 2025 5:42 pm
No need to apologise, I really appreciate you help and time.
I will have another go and let you know
Thanks again
Phil1322
Re: Macros
Postby Phil1322 » Tue Apr 01, 2025 6:34 pm
Unfortunately still no luck
Here is the error log
Errorlog.txt
(720 Bytes) Downloaded 85 times
Phil1322
