1.2116 won't start
1.2116 won't start
Postby Socke » Tue Apr 02, 2024 3:57 pm
I had 1.2113 running with some "small" problems (reproducable crash when finishing axis-calibration, reproducable bsod when changing the jogging-speed more than once), but running.
As I'm retrofitting a lathe, I installed 1.2116 on top of 1.2113 and the first start of 1.2116 ended in a crash. I uninstalled uccnc, checked that nothing is left in the registry, disabled unnecessary tools in autostart and installed fresh. But still no chance, the demo-choice-table comes up, after that the loading-bar won't get beyond 0% and then comes the crash.
My PC is a mini-pc with Intel Atom N2800, 4GB Ram, 64GB SSD and Windows 7-32 Pro.
What can i do, to get an idea, where the heart of the matter is?
Socke
Re: 1.2116 won't start
Postby cncdrive » Tue Apr 02, 2024 5:43 pm
It is probably an OpenGL problem. Try to update your video card drivers.
UCCNC 1.2116 requires higher OpenGL version than the previous UCCNC versions.
Postby Socke » Tue Apr 02, 2024 8:32 pm
Thanks for the hint. I found a newer driver from 2013 for this powerhouse... But although the integrated gpu supports open-gl, the drivers do not fully support it. So no luck.
I now installed the mesa 3D driver, and that does the trick, at least a bit. Uccnc now starts, but the program seems to run in slow motion. Every click needs 2 seconds to be acknoledged. Maybe i find another hint for this problem. The 1.2113 was lightning-fast...
Socke
Postby cncdrive » Tue Apr 02, 2024 9:53 pm
It's strange, because we changed to newer OpenGL functions to make the 3D graphics to run faster and more efficient which is true for the computers I saw so far.
I think that something is probably wrong in the implementation of framebuffers on your computer, but so far I did not see this kind of problem, so I don't know what it could be.
I see you mentioned you have 32 bits Windows, I would try to install 64 bits Windows 7 or 10 and check if it fixes the issue.
Postby Socke » Fri Apr 05, 2024 11:00 am
64 bits is no alternative, because there are no working drivers for this crappy integrated GPU. The Mesa 3D driver is a software-driver, hence the slow motion...
I guess, I'll have to use a different mini-pc. I have a I5-7500T, 8GB RAM, Win 10 Pro 64bit. It was planned for another machine. Hopefully that will do it.
Socke
Postby Socke » Fri Apr 12, 2024 7:32 am
Socke wrote:I guess, I'll have to use a different mini-pc. I have a I5-7500T, 8GB RAM, Win 10 Pro 64bit. It was planned for another machine. Hopefully that will do it.
That PC works well with 1.2116.
Socke
