Wrong movement direction of the Z-axis during homing
Postby VAMAKA » Tue Nov 21, 2023 4:46 pm
Hi, the problem is the Z-axis moving downwards during homing.
Details :
Software 1.2113
Firmware 1.0370
Device type UC300EHT- 5LPT
Z axis settings:
Step pin 7 port 2 Active low
Dir pin 8 port 2
Home pin 7 port 1 Active low
Homing speed up to 500 mm/min
Down 50
Softlimit - -160
Softlimit+ 0
Movements up and down are ok when controlled from the keyboard.
The machine has home switches on all axes and soft limits in use,
they work correctly.
I have tried with several settings without success.
Would there be a solution to the problem?
Best regards, VAMAKA
VAMAKA
Re: Wrong movement direction of the Z-axis during homing
Postby ger21 » Tue Nov 21, 2023 4:51 pm
Toggle the "Dir. Positive" checkbox.
Postby VAMAKA » Sun Nov 26, 2023 11:47 am
Thank you very much for your help, it works now!
VAMAKA
Users browsing this forum: No registered users and 42 guests
