is there an mpg count register available?
so i can check mpg position against time? "changes"
if not what is the best way of determining this?
i want to try to implement a "trycut function" (see feature requests)
basically making both g0 and g1,g2 g3 feedrate follow the speed the the mpg dial is turned at while a button is on.
resume to normal programmed feedrate when button is off.
