Feedrate in Programmode is ok in manual Mode to slow.
Postby Vikilaser » Mon Mar 13, 2023 12:48 pm
Hello,
I have some problems to get the right Feedrate in UCCNC.
I changed from mach3 to UCCNC and loaded the existing mach3 profile with all motortuning settings to UCCNC.
In the Programm mode the jogging feedrate is right for my example 3000mm/min. In mach3 all worked fine, but now in UCCNC the Jogging Feedrate is by hitting normal Hotkeys to slow in manual mode. In MDI its also ok. The machine drive with 3000mm/min. Also my Handwheel plugin dont works in UCCNC. I copied into tue plugin folder of UCCNC.
What changed i have to to?
Thanks!
Vikilaser
Re: Feedrate in Programmode is ok in manual Mode to slow.
Postby Vikilaser » Mon Mar 13, 2023 1:25 pm
I found the Problem. The feedrate was on 10% in the virtual pendant Settings.
Vikilaser
Users browsing this forum: Bing [Bot], Google [Bot] and 31 guests
