Arcs explode in UCCNC (Solidworks generated gcode)
I'm trying to draw a wakeboard and the front and back where there are tighter curves does not seem to output properly. The workflow is Solidworks -> Solidworks CAM with MACH_III_G54 post processor -> UCCNC -> Stepcraft. The file seems to be ok in Solidworks CAM NC Editor but when I load the same gcode file to UCCNC (or https://ncviewer.com/), I see that the curves become huge circles, like the center point would be in a wrong location. I thought this could be a visualisation problem but the cnc machine also starts to do this huge circle. I have isolated the problem to be the contour mill and have excluded everything else to make debugging easier.
This is how UCCNC and ncviewer.com draws the file
This is how Solidworks CAM NC Editor looks like
The gcode file attached as .txt. I can't figure out if there is a setting in Solidworks which makes this happen, this is the first time I'm seeing this but is sure annoying... It's just the contour mill which fails, all other operations are fine.
Any help would be highly appreciated![Smile :)](./images/smilies/icon_e_smile.gif)
