I have a small mill I want to interface a uc300 to . the Spindle speed control needs a 0-5V signal to operate it .
If I set the spindle parameters as min pwm duty cycle to 0% and max pwm duty cycle to 42% will that limit my output voltage to 0-5V ?
So if I have spindle min % at 10 and max% at 80 then it can output a voltage between 1.2V and 9.6V and the speed velocity min would be rpm that 1.2V produces and the spindle velocity max would be the rpm at 9.6V .
Is that correct ?
Battwell wrote:something i find strange. is if minimum pwm is set then this is output all the time. (in my mind this should only be on during spindle run)
minimum pwm is always output even when the spindle is off.
reason?
Users browsing this forum: No registered users and 31 guests
