Using I/o to function as a momentary switch
Postby Lucasclub » Thu Feb 16, 2023 2:59 am
I’m not really able to use the normal method of turning on my spindle via the use of relays…… because of the mill hardware doesn’t allow for it….on the mill there is a momentary switch that turns on the spindle….. so I want to run in parallel a way of mimicking a momentary switch…. Is this possible?
Lucasclub
Re: Using I/o to function as a momentary switch
Postby cncdrive » Fri Feb 17, 2023 12:18 am
Use a relay which bypasses the switch's contactors.
Users browsing this forum: No registered users and 31 guests
