M10 M11 comands
M10 M11 comands
Postby Vikilaser » Wed Feb 15, 2023 12:30 pm
Hello,
I have bougth the UCCNC Software.
How can I use the M10/M11 comands?
When I type in MDI M10 Q255 I dont see any change in the diagnostics...
Have I to activate something to use the M10/M11 comands?
I want to Switch in and off my laser by M10/M11...
I hope the Support can help me, for its all new for me...
Thank you!
Greetings Viktor
Vikilaser
Re: M10 M11 comands
Postby ger21 » Wed Feb 15, 2023 1:23 pm
I think you need M3 also.
Re: M10 M11 comands
Postby Vikilaser » Wed Feb 15, 2023 8:07 pm
Hello Gerry,
I have tried with the M3 comand (M3 M10 Q255).
In the diagnostics my Spindle is also on, but the light for the Laser pin17 port1 dont reacts...
Do you know why?
Thank you for your answer!
Greetings Viktor
Vikilaser
Re: M10 M11 comands
Postby Vikilaser » Fri Mar 10, 2023 7:37 am
Hi Gerry,
Now my Laser reacts to the M3 Sxxx comand but it still dont works with M3 M10 Qxxx comands to get the right intensity. The laser turns on but im not able to control the intensity by the Q comand. Maybe it is about my laser pin setting...
Im trying...
Viktor
Vikilaser
Re: M10 M11 comands
Postby Battwell » Fri Mar 10, 2023 3:29 pm
what bob are you using? pin 17 is often a relay.
try a different output number for laser pwm.
Re: M10 M11 comands
Postby Vikilaser » Fri Mar 10, 2023 5:28 pm
Hi Battwell,
Im using a Triple beast together with a UC-300ETH-5LPT.
I use this in combination with a delivered driver Adapter PDA-01 from Lasertree. My Laser is an LT-4LDS-V2 from Lasertree.
Vikilaser
Re: M10 M11 comands
Postby Vikilaser » Sat Mar 11, 2023 12:10 pm
Now i tryed pin 1 Port 3 as Laser pin and also pin 1 Port 3 as Spindle relay output. Spindle Pwm is on pin 17 Port 1. The triple beast gives pwm to pin 1 and 17 via LPT. I have the triple beast connected to Port 2 on the Uc-300eth. Ports 1,2 and 3 of the Uc-300eth have the same configs.
M3 Sxxx is working but M3 M10 Qxxx dont works. Im not able to control the power.
In I/O Setup (UCCNC) I dont have any settings,
only in Var-analog out1 I have chosen 1 and for Spindle pwm analog Chanel also 1
Somebody knows where the Problem is?
Vikilaser
Re: M10 M11 comands
Postby Vikilaser » Sat Mar 11, 2023 6:53 pm
Now also the M10/M11 comands are working i have had a false conection and config. Analog Port dont works, like cnc drive said. I misunderstanded and thoug I have to assign the laserpin to the analog Port. This was about my bad knowledge in electronics. I conected the pwm line to port3 pin1 and ground to pin 25 and it worked.
Thanks to all of you guys for understanding and helping me.
Great thanks to you very and batwell!
Also great thanks to Cnc-Drive!
Vikilaser
