UCCNC Homing problem!
Posted: Fri Nov 25, 2022 8:26 am
Ladies and Gentlemen (I'm sure there will be others too) I have a strange problem that I can't figure out how to deal with. I have AXBB+Mach4+Win10Pro. I have 4 axis+ spindle. I only have HOME inductive sensors.
Everything works and doesn't work. After approaching the sensor, the diode on the sensor lights up (in my case it goes out, because I have NC sensors) and the corresponding pin and the function assigned to it will light up in diagnostics. I have the appropriate pins on all axes except A (4), i.e. 4, 5 and 6, and the same for all functions. So pin4 is both HomeX and LimitX. When I find it or put a screwdriver to the sensor, the E-STOP switches on. So the Limits work correctly. I have software limits turned on. But they are of no use to me because I can't jam. It's just that nothing happens during Homing, either overall or individual axes. The wasp passes over the sensor, it sends a signal, but it doesn't adjust and doesn't go back, and thus it doesn't jam, and the wasps end up hitting:/
The answer from CNCshop is that they sold 50,000 licenses, so it must work. I don't doubt it, but I don't know why it just doesn't work for me. I have a fresh install of Windows and UCCNC, a new profile. I have Mach4home on the same computer and it F U N G U J E!!! Where should I look for the problem? After all, it must be some wrong setting or a program error, when it is correct in hardware. Please, give me an advice. Thank you
