Within "configuration" I performed the calibrations on the X,Y and Z axes, my machine is using metric values. And after doing so, when I manually command the mill to go to a specific integer like X900 it will go to X 899.9988 even when I use the step movement function of 1mm it will move to .9994 and then 1.9988 and then 2.9983 and then weirdly 4.0008 The first 3 are less than the desired 1mm movement, but then the final somewhat compensates. I have homed and zeroed all axes. Any thoughts? Thanks in advance for your time and consideration.
best,
