I'm pulling my hair out here. I've got a windows 7 machine with uccnc 1.211 installed. I'm connected via a switch OR cross over cable. I've used the network utility, I am able to scan the device, disable dhcp, and test the connection..
I'm even pinging continuously ping -t 10.10.10.11 from my machine and I'm getting replies.
But when I run the program, it always says connection problem, closing program. Once in a while It'll go all the way through and I can actually do things. But if I close the program and re-launch same problem. This is completely unreliable. I've had a smoothstepper here on this same computer with the same ethernet connection and I"ve never had a problem.
Any help would be appreciated. the ucxxx utility works every time. I can scan and find the device.
