andrewwong2000 wrote:Hi,
Am trying to install 1.2112 into a clean folder ( moved my working 1.2111 ).
So it's a clean install.
If I do demo mode, or select UC300-ETH without a license key, UCCNC loads fine.
If I install the licence key, it tries to update the firmware, then it says firmware done.
Immediately it will say "Lost contact with the controller " and I am forced to exit.
Is there a workaround or solution to this ?
Andrew
I have EXACTLY the same problem. Here is the short story:
I had a computer motherboard crash and had to buy a new PC. Bought a new HP EliteDesk 800 G5 with an Intel i7 8-core 9th generation CPU with Windows 10 Pro and all drivers updated. The new PC is of course much faster and better than the old Dell I had. It has M2 SSD disk as main and I did a clean install of the latest UCCNC and experienced the same problem. Installation goes well, UCCNC works in demo mode, but as soon as I have the license active and the UC300ETH is active the software crashes with the above erroro. Did several clean-ups and new installations but nothing worked. I had to revert back to my old 1.2049 which works without any problems. Everything else is the same as before, no change in the way the UC300ETH is connected, using the same IP address, connected to the same switch, so I am a bit puzzled and not happy about it, but at least 1.2049 is working fine.
My last efforts were a new clean installation and manually configuring everything, but have had no time to start up and test again. Maybe I'll do it today, but I don't keep my hopes high...
Something definitely seems wrong in the latest official release.
