Scaling Issue
Re: Scaling Issue
Postby delta21@gmail.com » Sun Jan 05, 2020 5:40 pm
Actually there is one under the axis tabs. But that one is at 1000.
So it can not be that one.
I changed it to 10 but then the machine makes minimini steps.
delta21@gmail.com
Re: Scaling Issue
Postby delta21@gmail.com » Sun Jan 05, 2020 5:44 pm
Actually there is a field under the axis tabs. Its at 1000 now.
Just to test I put it at 10. Then it made miminini steps.
What you think?
delta21@gmail.com
Re: Scaling Issue
Postby Robertspark » Sun Jan 05, 2020 5:46 pm
1000/2.5 = 400 on my calculator....
400 would align with a direct driven ball screw with a 5mm pitch driven by a common 200 step per revolution stepper motor with the drive set with 10 micro steps setting
200steps per rev X 10uSteps /5mm
Rob
UCCNC v1.2110 Macro Manual
Re: Scaling Issue
Postby delta21@gmail.com » Sun Jan 05, 2020 6:05 pm
Robert
I do now understand. You helped a lot and with understandable input. You understand that software and the relations quite well.
In my mind, I thought 1 unit would always be 1mm as UCCNC is in MM. I did not think about those different setups around in the world which UCCNC needs to address.
That is the reason I did not make the connection on the 1000/2.5. I feel bit stupid now but happy :-)
UCCNC must have an Mill setup with an ball screw size where 1 unit is 1mm as a standard. And every other must be scaled up or down to get 1mm per unit.
I understand now.
You were of great help Robert. So thank you very much!
Karl
delta21@gmail.com
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
