Battwell wrote:but the raster engraving plugin does activate m3 (swaps from m4 to m3 if m4 is already active)
So it does - I did not know it did that Perhaps my system of individually switching Laser / Spindle is not so shabby
i want to use the laser for engraving part/joint numbers on plywood before or after cutting with the router.
so ideally want to get it all going nicely in the same profile.
i can offset the laser using g52 in a macroloop if m4 is active im hoping.
Doubtful you would ever want to use the raster engraving plugin for this but however you do it you would have two separate operations / toolpaths. Best to laser first then router cut second (reduces the risk of setting fire to wood dust / shavings).
I think I'm going to do this based on tool number.
Il set laser as tool 96.
That way I can exclude it from being probed, set it's offset and set an output pin to switch it on.
I am not sure that would work but I would be interested to hear if you are able to control laser output power.
