Hi All,
I have the new AXBB board which I am really impressed with, I am however having some difficulty wiring up the limit switches to the board?
The limit switches I have are similar to the following:
https://m.dhgate.com/product/wholesale- ... 23383.html
Previously I had NCStudio and these were wired to the +5v, -5v, and the third wire was the signal wire.
I had wired these similar on the AXBB board with the two 5v wires connected to the 5v output port and the third wire wired to one negative connection on Port 2 with a link wire connected from the +5v into the + side on port 2.
There are 3x limit switches in total one for each axis, I managed to get X & Y working ok however I'm struggling on the Z axis all 3x limit switches are wired and the settings are identical.
Can some advise first if I have these wired correctly, if I have can you advise why the Z axis keeps going into reset?
Kind regards
