by jsim8909 » Tue Mar 26, 2019 10:41 pm
Hello, I am having trouble understanding the probing screen version 1.2109. I enabled the probe plugin, read the descriptions found on via the i tab. I am using a spindle mounted touch probe. First attempt set to touch probe page 1 set probe radius on setup page. choose single probe action page 1 and y axis 25mm. Set saze z 15 mm and clicked safe probe mode. Last I hit start probing and that button changed green and messages says probing. Nothing happens. no movement, no messages of any kind. machine was homed and 150 mm away from all limits hard and soft. what am I missing? I put all I had into understanding this new screen, but It's next to impossible to understand function of whole process when all the instruction is limited to button description only. We need a step 1,2,3 ect for at least 1 of the options. Like after machine is homed you wanna outside probe stock in way both sides with a touch probe. You set what buttons to what and the setup values what in relation to ur stock relative to size?
Life is what happens when your busy making other plans!
