May be you can help me...
I am try to run gcode from desired position and I need to enable M10 laser output for enable THC.
Without M10 all work fine:
- Code: Select all
UC.Setfield(true, (double)(line_number), 866); //set line number
UC.Validatefield(true, 866);
UC.Callbutton(169); //Sets the G-code execution pointer to the line defined in the 866 field
UC.Wait(100);
UC.Codesync("M3"); // M3 issue
UC.RemoveRunfromhere();
UC.Callbutton(128); // call START button
But if I am try to add M10 code for enabling laser output - code halted.
- Code: Select all
UC.Wait(100);
UC.Codesync("M10"); //-> insert M10 to activate laser output
Do you have any things about this?
Thank you!!
