Will this encoder work with NCCNC
Postby NUDEcnc » Tue Dec 11, 2018 8:23 pm
Question about spindle: JGL-100/2.5R24-25 - ATC spindle 24000rpm 2.5kW from
http://www.jian-ken.com/electric-spindl ... indle.html
I did receive information abut encoder in the spindle:
Can you please confirm if this encoder will work with NCCNC?
My goal is to have a rigid taping.
CPU cooling made by me: http://www.nudecnc.eu
NUDEcnc
Re: Will this encoder work with NCCNC
Postby NUDEcnc » Tue Dec 11, 2018 8:33 pm
I want to connect this with UC300ETH-UB1. I understand that this is where I should connect this:
5 channels of 5Vdc isolated NPN inputs including X210-X215 which is suitable for low
voltage devices such as MPG, encoder
And TTL signal output is correct for the UCCNC?
NUDEcnc
Postby ger21 » Tue Dec 11, 2018 10:28 pm
That spindle isn't suitable for rigid tapping. If you run it under 6000 rpm, you may damage it.
Postby NUDEcnc » Sat Dec 15, 2018 9:31 pm
First "ger21" thank you for your support and finding errors in my ideas :)
"12 steps" - 1st We admitted we were powerless without knowledge !!! :)
I did contact manufacturer and ...
They are really helpful and supportive but I don't think they ever did this kind of tests.
I have an arrangement that I will do tests and if I damage spindle they will be more than happy to take it for an autopsy and warranty replacement.
So the plan is simple: squeeze sh.. out of the spindle and see what happens :)
I also did get more info about encoder:
NUDEcnc
Postby ger21 » Sat Dec 15, 2018 9:53 pm
The link in your signature is spelled wrong. Nice stuff.
Postby NUDEcnc » Sat Dec 15, 2018 10:33 pm
Thank you. linked corrected :)
"BE THE BEST OR DIE TRYING !!
NUDEcnc
Users browsing this forum: No registered users and 27 guests
