uc300eth/UB1 Traveling speed lower than expected/set
Postby Evgenij » Wed Nov 21, 2018 8:38 am
I'm trying to configure UCCNC/UB1 for my custom machine and facing really strange issue.
I'm using Nema23 573HBM20-1000 Stepper with HBS57-Drivers and Ballscrew pitch of 5 mm.
I set following values for the x-axis in ucnc:
Kernel-Speed: 200kHz
Steps per Unit 800
Velocity: 14250
All Setting(General Tab) -> https://drive.google.com/open?id=1XC6mS ... HkoUkl5L6J
All Setting(X-Axis). -> https://drive.google.com/open?id=1JKnn1 ... qttov7WPrE
If I move x axis in ucnc for example for 10mm, than it moves for 10mm. BUT with max velocity of <3m/min instead of 14m/min.
I've made two short videos to show the problem. In first video you can see quick measurement with 17,5mm travel.
https://drive.google.com/open?id=1UsliB ... jq2XwWOGfu
The second one shows the max velocity/travel speed of 14,2m/min :cry:
What can be going wrong here?
Evgenij
Re: uc300eth/UB1 Traveling speed lower than expected/set
Postby Robertspark » Wed Nov 21, 2018 1:24 pm
how are you moving the axis?
jogging , gcode or mdi entry?
your jog feedrate in those videos is 10% so it won't move very fast
Postby Evgenij » Wed Nov 21, 2018 2:42 pm
Robertspark wrote:how are you moving the axis?
Hello Rob,
yes, the problem was in front of the keyboard :lol:
Thanks for the help.
Evgenij
Postby Robertspark » Wed Nov 21, 2018 2:46 pm
No problem, welcome to the UCCNC user group :D
Postby Robertspark » Wed Nov 21, 2018 3:14 pm
here is a bit of test code that may help you out (in metric)
G92 X0 Y0 Z0
G0 X20
G91
G0 Z25
M98 P200 L2
M98 P201 L2
M98 P202 L2
M98 P203 L2
G0 Y25
M98 P204 L2
G0 Y-25
G0 Z-25
G90
G0 X0
M30
O200
G1 X50 F3000
G1 X-50
M99
O201
G1 Y50 F3000
G1 Y-50
M99
O202
G1 Y50 F3000
G1 X50
G1 Y-50
G1 X-50
M99
O203
G1 X50 F3000
G1 Y50
G1 X-50
G1 Y-50
M99
O204
G02 X0 Y0 I25 J0 F3000
G03 X0 Y0 I25 J0
G03 X25 Y0 I12.5 J0
G02 X25 Y0 I12.5 J0
G02 X-50 Y0 I-25 J0
M99
if you are using a dial indicator you can position it at the start point (on the LHS...) and it will check for lost steps (+ backlash)
Users browsing this forum: renatom and 21 guests
