Hi Deszoe, was hoping for a function that gives the modal, the field in some cases don't update quick enough, hoping you possibly have a solution.
I been working on my FHP plugin and in some scenarios/conditions it has problems, not being able to retrieve the correct modal makes this task impossible to fix.
I put a messagebox with line number and modals after a Stop() to see problem and are not accurate. Messagebox shows line 30 and modal G3. If you look at X,Y dro's UCCNC is in line 31 in G1 modal.
Line 31
Thanks.
