Hi, I have the UB1 board attached via a cross direct network cable to the host PC, with the license installed and configured via the network utility. When scanning using the utility the controller appears twice in the list - same IP address and same license ID... When starting UCCNC, the same thing happens and the controller appears twice first item in the list of devices, which blocks UCCNC to automatically detect it and start the program without offering the selection of devices. once one of the instances is selected, the application continues just fine and I can communicate with the controller perfectly. I know there is a command line parameter to force UCCCNC to start with a specific device ID, but haven't used it yet and don't know if will work in this case. One thing to mention, is that the PC has a wireless network card as well and both adapters (wifi and ethernet) are enabled (each has different IP address though). I've tried re-installing everything from scratch (even Win10 cleanly) and the same thing happens..
Any idea how to resolve?
Ronen
