Page 1 of 2
UC300ETH Firmware Error
Posted:
Sat Sep 15, 2018 7:40 am
by peini7
Hi there,
i'am new to UCCNC and i've ordered a UC300ETH. I've copied my license key into the UCCNC folder, plugged in my UC300ETH but the software always says "Connection lost" directly after startup.
The green led on the board is flashing long and then 2 times short which, as stated in the manual, means "Firmware error".
What can i do now?
I've already reset the device for two times but this has not resolved the problem.
I can ping the device but the UC utility is not showing up the device.
Thanks.
Daniel
Re: UC300ETH Firmware Error
Posted:
Sat Sep 15, 2018 1:04 pm
by Robertspark
Have you got the right cable?
You want a crossover ethernet cable for direct connection , pc<>uc300eth
Have you checked the pins (cable colours)in the rj45 to confirm?
Posted:
Sat Sep 15, 2018 2:16 pm
by peini7
Thank you for your reply.
I've connected the UC300 to my LAN, not directly to a PC.
Does it only work with a crossover cable directly connected to PC?
But with my setup, i can ping the device.
But the blinking of the led means "Firmware error". What does that mean exactly?
Posted:
Sat Sep 15, 2018 2:38 pm
by ger21
When you start UCCNC,it should connect to the UC300ETH, and automatically update the firmware if there's a problem.
It sounds like you don't have the network settings correct, and the UC300ETH is not connecting to UCCNC.
If you have a newer PC, you may not need a crossover cable for a direct connection, as the network adapter will auto detect the cable being used.
I would try a direct connection. Follow the manual and setup the network accordingly. Once you get that working, you can try connecting it over your LAN.
Posted:
Sat Sep 15, 2018 2:48 pm
by Robertspark
Probably because the firmware is not loaded, I would not worry about it until uccnc loads and connects to the u300eth, it will load the latest firmware at that point.
Ok, so you are connecting via your lab, you need a straight through cable then.
Then you have two options
Option a) change your network to match with what the uc300eth is looking for (subnet mask and static IP address for the uc300eth)
Option b) change the uc300eth to blend in with your network (this will require changing the subnet mask and IP address that the uc300eth looks for), this will require you first to (in my opinion, and it will be a good test that your uc300eth is working just fine), get yourself a crossover cable (or make one) and plug the uc300eth directly to your pc (with some ethernet cards you don't actually need to do this as they will auto configure the network connection to straight through or crossover (offhand I cannot remember the term for what to look for in the ethernet card specifications).
Then configure your ethernet card and ipadress as listed in the uc300eth manual
Then use the utility to change the uc300s subnet mask and static IP address to align with YOUR network.
Plug the uc300 back into your network and reset all your ethernet cards settings to your network and everything should work just fine.
I suspect your network and the uc300 are on different subnet masks
Posted:
Sat Sep 15, 2018 2:55 pm
by peini7
Ok i've connected the UC300 directly to my PC and it showed up in the UC utility. I've now set a valid static ip and re plugged it to my local network.
Ping works fine, and also UCCNC finds the device. It sometimes shows the message "Firmware update done" but after a few seonds it says "Connection lost".
Posted:
Sat Sep 15, 2018 3:00 pm
by ger21
Do you have a different cable to try?
Posted:
Sat Sep 15, 2018 3:49 pm
by peini7
Thanks. I've got it to work now with a direct connection.
I think its important to disable wifi or any other secondary ethernet adapter when connecting directly.
Posted:
Sat Sep 15, 2018 4:05 pm
by ger21
No, it's not, if it's configured correctly.
I've had it working directly with a desktop PC with two ethernet adapters, and on a laptop with an ethernet port and wifi enabled.
Posted:
Sun Sep 16, 2018 5:00 pm
by peini7
Ok now its working correctly also with wifi active.
Don't know why it had not worked before...
But thanks to all for your support.
