UCCNC 4 times slower cutting curve than straight
Postby Tulnukas » Thu Sep 06, 2018 7:01 pm
Hi!
My DIY CNC can jog 6000mm/min and cut 4000mm/min. I'm running UC400ETH and UCCNC with 3A Nema23 and other electronics on 48V. Also, I have 1610 ballscrews. Problem is that when I cut curved cuts, my CNC will slow down 4 times, and when it cuts a straight line, it will go max Fset around 4000mm/min. I have UCCNC general settings running default on CV mode. I added video to youtube.
Video:
https://www.youtube.com/watch?v=zICqHV-xG4o
Best wishes!
Martin
Tulnukas
Re: UCCNC 4 times slower cutting curve than straight
Postby spumco » Fri Sep 07, 2018 8:31 pm
Can you post some of the code, including the curved (slow) and fast (straight) parts?
Also, can you share your axis settings? Velocity & accel settings?
spumco
Postby Derek » Sat Sep 08, 2018 12:54 am
The problem is that UCCNC is very sensitive to under powered machines when multiple line segments are involved. This has been discussed a lot and you may be able to get it better with your CV settings but I have tried everything in the book and nothing helps. I was running my mill today and it was doing a 1" circle at 80 IPM. The best it would do is 30 IPM. I converted the code from line segments to arcs in CAM and it had zero problems holding 79.5 IPM. If you raise your acceleration values you will see improvement but if you are under powered you will see it a lot. None of my 4 machines running UCCNC can accelerate fast enough to make line segments as smooth as arcs. Arcs are smooth as silk and very accurate but line segments not so much.
Go into simulation mode and turn your acceleration way up and if that is the problem you will see the feeds normalize. Now build a machine around those values and you are all set:)
Derek
Postby ger21 » Sat Sep 08, 2018 2:10 am
Try increasing your error tolerance settings.
Postby Tulnukas » Sat Sep 08, 2018 9:29 am
Hi!
Thank you for the fast reply. My axis are 6000mm/min velocity and 200 acceleration.
I now changed curves to arcs and gcode shrink 10x. I added gcode with the previous version and modified.
Previous version:
https://www.dropbox.com/s/9pdkcl63m23xp ... 1.txt?dl=0
New version:
https://www.dropbox.com/s/toincrkdlw2hm ... 2.txt?dl=0
I haven't tried it out yet, but I go do it soon as I can.
Thanks!
Tulnukas
Postby Tulnukas » Sun Sep 09, 2018 3:06 pm
I got it working by making all the curves to arcs. But something is still making spindle to almost stop at the centre of this arc. I don't know how to repair that, can someone check my gcode and give me help, please. Is there some CV setting that tells CNC to stop in the center of arc when it changes direction. If I have to change some settings in general, can someone give me tips on what direction do I have to change them?
Current CV settings:
Linear error max: 0.03
Linear addition lenght max: 1
Linear unify lenght max: 2
Corner error max: 0.03
Arc radius tolerance: 0.1
Gcode:
( Profile 2 )
( File created: Sunday September 09 2018 - 05:54 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 135.000, Y= 560.000, Z= 20.000)
(Toolpaths used in this file:)
(Profile 2)
(Tools used in this file: )
(1 = End Mill {6 mm})
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (End Mill {6 mm})
N140G00G43Z20.000H1
N150S20000M03
N160(Toolpath:- Profile 2)
N170()
N180G94
N190X0.000Y0.000F3500.0
N200G00X-0.499Y0.000Z5.000
N210G1Z-2.929F3500.0
N220G1X-0.499Y20.000
N230G2X-0.196Y21.314I3.000J0.000
N240G3X24.066Y128.847I-215.999J105.237
N250G1X23.940Y133.315
N260G1X23.814Y137.784
N270G3X-0.196Y231.788I-240.009J-11.233
N280G2X0.326Y235.168I2.697J1.314
N290G2X10.235Y244.076I61.224J-58.139
N300G1X10.256Y244.092
N310G2X67.500Y263.000I56.623J-75.318
N320G2X124.745Y244.092I0.621J-94.229
N330G1X124.765Y244.076
N340G2X134.674Y235.168I-51.343J-67.076
N350G2X135.196Y231.788I-2.175J-2.066
N360G3X111.125Y136.374I216.001J-105.237
N370G1X111.025Y131.904
N380G1X110.925Y127.435
N390G3X135.196Y21.314I240.272J-0.884
N400G2X135.499Y20.000I-2.697J-1.314
N410G1Y0.000
N420G2X132.499Y-3.000I-3.000J0.000
N430G1X112.554
N440G2X110.892Y-2.498I0.000J3.000
N450G3X71.951Y10.351I-42.855J-64.446
N460G1X67.520Y10.448
N470G1X67.480
N480G1X63.049Y10.351
N490G3X24.108Y-2.498I3.914J-77.292
N500G2X22.447Y-3.000I-1.661J2.498
N510G1X2.501
N520G2X-0.499Y0.000I0.000J3.000
N530G1Z-5.857
N540G1X-0.499Y20.000
N550G2X-0.196Y21.314I3.000J0.000
N560G3X24.066Y128.847I-215.999J105.237
N570G1X23.940Y133.315
N580G1X23.814Y137.784
N590G3X-0.196Y231.788I-240.009J-11.233
N600G2X0.326Y235.168I2.697J1.314
N610G2X10.235Y244.076I61.224J-58.139
N620G1X10.256Y244.092
N630G2X67.500Y263.000I56.623J-75.318
N640G2X124.745Y244.092I0.621J-94.229
N650G1X124.765Y244.076
N660G2X134.674Y235.168I-51.343J-67.076
N670G2X135.196Y231.788I-2.175J-2.066
N680G3X111.125Y136.374I216.001J-105.237
N690G1X111.025Y131.904
N700G1X110.925Y127.435
N710G3X135.196Y21.314I240.272J-0.884
N720G2X135.499Y20.000I-2.697J-1.314
N730G1Y0.000
N740G2X132.499Y-3.000I-3.000J0.000
N750G1X112.554
N760G2X110.892Y-2.498I0.000J3.000
N770G3X71.951Y10.351I-42.855J-64.446
N780G1X67.520Y10.448
N790G1X67.480
N800G1X63.049Y10.351
N810G3X24.108Y-2.498I3.914J-77.292
N820G2X22.447Y-3.000I-1.661J2.498
N830G1X2.501
N840G2X-0.499Y0.000I0.000J3.000
N850G1Z-8.786
N860G1X-0.499Y20.000
N870G2X-0.196Y21.314I3.000J0.000
N880G3X24.066Y128.847I-215.999J105.237
N890G1X23.940Y133.315
N900G1X23.814Y137.784
N910G3X-0.196Y231.788I-240.009J-11.233
N920G2X0.326Y235.168I2.697J1.314
N930G2X10.235Y244.076I61.224J-58.139
N940G1X10.256Y244.092
N950G2X67.500Y263.000I56.623J-75.318
N960G2X124.745Y244.092I0.621J-94.229
N970G1X124.765Y244.076
N980G2X134.674Y235.168I-51.343J-67.076
N990G2X135.196Y231.788I-2.175J-2.066
N1000G3X111.125Y136.374I216.001J-105.237
N1010G1X111.025Y131.904
N1020G1X110.925Y127.435
N1030G3X135.196Y21.314I240.272J-0.884
N1040G2X135.499Y20.000I-2.697J-1.314
N1050G1Y0.000
N1060G2X132.499Y-3.000I-3.000J0.000
N1070G1X112.554
N1080G2X110.892Y-2.498I0.000J3.000
N1090G3X71.951Y10.351I-42.855J-64.446
N1100G1X67.520Y10.448
N1110G1X67.480
N1120G1X63.049Y10.351
N1130G3X24.108Y-2.498I3.914J-77.292
N1140G2X22.447Y-3.000I-1.661J2.498
N1150G1X2.501
N1160G2X-0.499Y0.000I0.000J3.000
N1170G1Z-11.714
N1180G1X-0.499Y20.000
N1190G2X-0.196Y21.314I3.000J0.000
N1200G3X24.066Y128.847I-215.999J105.237
N1210G1X23.940Y133.315
N1220G1X23.814Y137.784
N1230G3X-0.196Y231.788I-240.009J-11.233
N1240G2X0.326Y235.168I2.697J1.314
N1250G2X10.235Y244.076I61.224J-58.139
N1260G1X10.256Y244.092
N1270G2X67.500Y263.000I56.623J-75.318
N1280G2X124.745Y244.092I0.621J-94.229
N1290G1X124.765Y244.076
N1300G2X134.674Y235.168I-51.343J-67.076
N1310G2X135.196Y231.788I-2.175J-2.066
N1320G3X111.125Y136.374I216.001J-105.237
N1330G1X111.025Y131.904
N1340G1X110.925Y127.435
N1350G3X135.196Y21.314I240.272J-0.884
N1360G2X135.499Y20.000I-2.697J-1.314
N1370G1Y0.000
N1380G2X132.499Y-3.000I-3.000J0.000
N1390G1X112.554
N1400G2X110.892Y-2.498I0.000J3.000
N1410G3X71.951Y10.351I-42.855J-64.446
N1420G1X67.520Y10.448
N1430G1X67.480
N1440G1X63.049Y10.351
N1450G3X24.108Y-2.498I3.914J-77.292
N1460G2X22.447Y-3.000I-1.661J2.498
N1470G1X2.501
N1480G2X-0.499Y0.000I0.000J3.000
N1490G1Z-14.643
N1500G1X-0.499Y20.000
N1510G2X-0.196Y21.314I3.000J0.000
N1520G3X24.066Y128.847I-215.999J105.237
N1530G1X23.940Y133.315
N1540G1X23.814Y137.784
N1550G3X-0.196Y231.788I-240.009J-11.233
N1560G2X0.326Y235.168I2.697J1.314
N1570G2X10.235Y244.076I61.224J-58.139
N1580G1X10.256Y244.092
N1590G2X67.500Y263.000I56.623J-75.318
N1600G2X124.745Y244.092I0.621J-94.229
N1610G1X124.765Y244.076
N1620G2X134.674Y235.168I-51.343J-67.076
N1630G2X135.196Y231.788I-2.175J-2.066
N1640G3X111.125Y136.374I216.001J-105.237
N1650G1X111.025Y131.904
N1660G1X110.925Y127.435
N1670G3X135.196Y21.314I240.272J-0.884
N1680G2X135.499Y20.000I-2.697J-1.314
N1690G1Y0.000
N1700G2X132.499Y-3.000I-3.000J0.000
N1710G1X112.554
N1720G2X110.892Y-2.498I0.000J3.000
N1730G3X71.951Y10.351I-42.855J-64.446
N1740G1X67.520Y10.448
N1750G1X67.480
N1760G1X63.049Y10.351
N1770G3X24.108Y-2.498I3.914J-77.292
N1780G2X22.447Y-3.000I-1.661J2.498
N1790G1X2.501
N1800G2X-0.499Y0.000I0.000J3.000
N1810G1Z-17.571
N1820G1X-0.499Y20.000
N1830G2X-0.196Y21.314I3.000J0.000
N1840G3X24.066Y128.847I-215.999J105.237
N1850G1X23.940Y133.315Z-16.500
N1860G1X23.814Y137.784Z-17.571
N1870G3X-0.196Y231.788I-240.009J-11.233
N1880G2X0.326Y235.168I2.697J1.314
N1890G2X10.235Y244.076I61.224J-58.139
N1900G1X10.256Y244.092
N1910G2X67.500Y263.000I56.623J-75.318
N1920G2X124.745Y244.092I0.621J-94.229
N1930G1X124.765Y244.076
N1940G2X134.674Y235.168I-51.343J-67.076
N1950G2X135.196Y231.788I-2.175J-2.066
N1960G3X111.125Y136.374I216.001J-105.237
N1970G1X111.025Y131.904Z-16.500
N1980G1X110.925Y127.435Z-17.571
N1990G3X135.196Y21.314I240.272J-0.884
N2000G2X135.499Y20.000I-2.697J-1.314
N2010G1Y0.000
N2020G2X132.499Y-3.000I-3.000J0.000
N2030G1X112.554
N2040G2X110.892Y-2.498I0.000J3.000
N2050G3X71.951Y10.351I-42.855J-64.446
N2060G1X67.520Y10.448Z-16.518
N2070G1X67.480Z-16.518
N2080G1X63.049Y10.351Z-17.571
N2090G3X24.108Y-2.498I3.914J-77.292
N2100G2X22.447Y-3.000I-1.661J2.498
N2110G1X2.501
N2120G2X-0.499Y0.000I0.000J3.000
N2130G1Z-20.500
N2140G1X-0.499Y20.000
N2150G2X-0.196Y21.314I3.000J0.000
N2160G3X24.066Y128.847I-215.999J105.237
N2170G1X23.940Y133.315Z-16.500
N2180G1X23.814Y137.784Z-20.500
N2190G3X-0.196Y231.788I-240.009J-11.233
N2200G2X0.326Y235.168I2.697J1.314
N2210G2X10.235Y244.076I61.224J-58.139
N2220G1X10.256Y244.092
N2230G2X67.500Y263.000I56.623J-75.318
N2240G2X124.745Y244.092I0.621J-94.229
N2250G1X124.765Y244.076
N2260G2X134.674Y235.168I-51.343J-67.076
N2270G2X135.196Y231.788I-2.175J-2.066
N2280G3X111.125Y136.374I216.001J-105.237
N2290G1X111.025Y131.904Z-16.500
N2300G1X110.925Y127.435Z-20.500
N2310G3X135.196Y21.314I240.272J-0.884
N2320G2X135.499Y20.000I-2.697J-1.314
N2330G1Y0.000
N2340G2X132.499Y-3.000I-3.000J0.000
N2350G1X112.554
N2360G2X110.892Y-2.498I0.000J3.000
N2370G3X71.951Y10.351I-42.855J-64.446
N2380G1X67.520Y10.448Z-16.518
N2390G1X67.480Z-16.518
N2400G1X63.049Y10.351Z-20.500
N2410G3X24.108Y-2.498I3.914J-77.292
N2420G2X22.447Y-3.000I-1.661J2.498
N2430G1X2.501
N2440G2X-0.499Y0.000I0.000J3.000
N2450G00Z5.000
N2460G00Z20.000
N2470G00X0.000Y0.000
N2480M09
N2490M30
Tulnukas
Postby ger21 » Sun Sep 09, 2018 3:37 pm
When you use tabs in Vectric products, the g-code actually has the tab moves at every level, so where it's slowing down, there are two short straight segments above the tabs. The only thing that will really help, is increasing acceleration, or not using tabs.
Postby Tulnukas » Sun Sep 09, 2018 4:18 pm
ger21 wrote:When you use tabs in Vectric products, the g-code actually has the tab moves at every level, so where it's slowing down, there are two short straight segments above the tabs. The only thing that will really help, is increasing acceleration, or not using tabs.
Is there any way to repair the gcode, but still use tabs?
Tulnukas
Postby ger21 » Sun Sep 09, 2018 4:38 pm
You can hand edit it.
Take this:
And change it to this
N270G3X-0.196Y231.788I-215.999J105.237
Use the I and J coordinates from the first G3
with the X and Y from the second G3.
Do it for every pass except the last one, wherever there's a tab.
Postby Tulnukas » Sun Sep 09, 2018 5:53 pm
ger21 wrote:You can hand edit it.
Take this:
Thanks for the tip!
I changed gcode like you advised, but problem is that this will change the shape of the cut. If you see tee final third tab that I removed from G3, it will go bit crooked and will not cover final cut exactly. I guess I have to try to change some settings in CV or something. But if I can't get this to work, I have to go back to Mach3 unfortunately. :(
New gcode:
( Profile 2 )
( Material Size)
(Profile 2)
N110G71G91.1
N120T1M06
N140G00G43Z20.000H1
N150S20000M03
N170()
N180G94
N390G3X135.196Y21.314I216.001J-105.237
N410G1Y0.000
N430G1X112.554
N490G3X24.108Y-2.498I-42.855J-64.446
N510G1X2.501
N530G1Z-5.857
N590G3X-0.196Y231.788I-215.999J105.237
N710G3X135.196Y21.314I216.001J-105.237
N730G1Y0.000
N750G1X112.554
N810G3X24.108Y-2.498I-42.855J-64.446
N830G1X2.501
N850G1Z-8.786
N910G3X-0.196Y231.788I-215.999J105.237
N1030G3X135.196Y21.314I216.001J-105.237
N1050G1Y0.000
N1070G1X112.554
N1130G3X24.108Y-2.498I-42.855J-64.446
N1150G1X2.501
N1170G1Z-11.714
N1230G3X-0.196Y231.788I-215.999J105.237
N1350G3X135.196Y21.314I216.001J-105.237
N1370G1Y0.000
N1390G1X112.554
N1450G3X24.108Y-2.498I-42.855J-64.446
N1470G1X2.501
N1490G1Z-14.643
N1550G3X-0.196Y231.788I-215.999J105.237
N1670G3X135.196Y21.314I216.001J-105.237
N1690G1Y0.000
N1710G1X112.554
N1770G3X24.108Y-2.498I-42.855J-64.446
N1790G1X2.501
N1810G1Z-17.571
N1870G3X-0.196Y231.788I-215.999J105.237
N1990G3X135.196Y21.314I216.001J-105.237
N2010G1Y0.000
N2030G1X112.554
N2090G3X24.108Y-2.498I-42.855J-64.446
N2110G1X2.501
N2130G1Z-20.500
N2190G3X-0.196Y231.788I-215.999J105.237
N2310G3X135.196Y21.314I216.001J-105.237
N2330G1Y0.000
N2350G1X112.554
N2430G1X2.501
N2450G00Z5.000
N2460G00Z20.000
N2480M09
N2490M30
Tulnukas
Users browsing this forum: No registered users and 30 guests
