Plugin too fast for Constructor macro
Hi Balazs,
here's a copy of something I posted on Cnczone (I thought the forum was still down, my link button didn't work anymore):
I've just found out an interesting connection between DROs which are kept persistent by the Constructor and Destructor macros (Writekey and Readkey), and a plugin which reads those DRO values.
I had code in the "firstrun" block of the plugin 25hz loop method. This code reads the value of a persistent DRO.
However I just couldn't figure out why the DRO value was not being read, then I though maybe the plugin starts very quickly whereas the Constructor macro is a bit of a snail and takes time to finish doing its thing (i.e. writing the value to the DRO).
It appears this theory may be correct because I got things working by having a countdown in the 25hz loop before any of my loop code ran. In my case I had to let the 25hz loop run a minimum of 5 times without executing any of my code.
I would guess that with a Constructor macro with a lot more code it would take longer to complete and therefore a plugin which needed to read "persistent" DROs would have to "delay" for longer before it attempted to read those DROs.
I've asked Cncdrive if it would be a good modification to UCcnc to prevent plugins running until the Constructor macro has completed, otherwise if a plugin immediately attempts to read a "persistent" DRO but the Constructor macro hasn't yet written the value to that DRO..................................
Any thoughts on that one ??
Keith
Keith
