Programming a Macro as a canned cycle ???
Re: Programming a Macro as a canned cycle ???
Postby Robertspark » Fri Aug 31, 2018 1:48 pm
Yes, you can pass the variables to the M-code via the example in the manual (page 62/87 in the current development version manual, section 4.1.2 M-codes)
(I've done it a couple of times I'm just not at my home PC for an example I'll try to load one tonight)
That G96 attempt did it:
viewtopic.php?f=20&t=822
Postby Robertspark » Fri Aug 31, 2018 4:16 pm
Well, you can't send parameter "F" so would need to substitute it with another letter (same with "S")
I don't see what the difference between
G81 X1 Y2 Z-1 R.050 F20
and
M81 X1 Y2 Z-1 R.050 Q20
would be. I'm obviously missing something really obvious
Postby Robertspark » Fri Aug 31, 2018 5:54 pm
Vmax549 wrote:But back to the original question?
I'm still not seeing what the problem is....
Input variables to macro
Use variables in macro
Output exec.code()
Done...
What do you want the gcode / macro to do I can do a g12/g13 macro (I think I may have already posted one some time ago as I got it from Peter Smids book
Postby Robertspark » Fri Aug 31, 2018 5:56 pm
viewtopic.php?f=13&t=638&p=4556&hilit=G12#p4556
AHH I didn't post it just asked if it was wanted
Postby ger21 » Fri Aug 31, 2018 8:52 pm
Your M code would need to be modal...
Postby cncdrive » Fri Aug 31, 2018 9:03 pm
You can make global variables in the macro and then when you passing through the variables you can test them for null and if they are null then you don't change the previous global value.
The variables will keep their values as long as your macro code is not changed, because then the UCCNC will not recompile the macro if the macro text is the same and so your variables can be handled in the macro as modal.
Users browsing this forum: No registered users and 19 guests
