Sending a keypress to UCCNC
Re: Sending a keypress to UCCNC
Postby cncdrive » Fri Aug 10, 2018 5:09 pm
A macroloop is the same as a macro, the language is the same, but a macroloop as it's name says runs infinately so you can do/update things periodically.
Postby jvalencia » Fri Aug 10, 2018 5:40 pm
Hello admin. What's the limitation that stops running a macro when the cycle is active?
I have this simple macro attached to a hotkey and it works, but not when a cycle is running.
M20000.txt
AS3.Setfield(0, 232);
AS3.Validatefield(232);
jvalencia
Postby cncdrive » Fri Aug 10, 2018 5:51 pm
Macros don't run when there is cycle or MDI cycle. Macroloops do.
Postby jvalencia » Fri Aug 10, 2018 6:29 pm
jvalencia wrote:Hello admin. What's the limitation that stops running a macro when the cycle is active?
M20000.txt
So my only solution now is to use the serial port in a macroloop AFAIK.
I'll try next week then, thanks ;)
jvalencia
Postby dezsoe » Sat Aug 11, 2018 1:06 pm
You could write a plugin to handle the keypresses and it works also while cycle is running. Then you don't need to program serial communication.
Postby jvalencia » Sun Aug 12, 2018 5:17 pm
I gave modbus another chance and now it's working. Last time I had problems with it but for now it works.
Let me cross my fingers...
This is the control box btw. It has Cycle Start (green), Feed override (potentiometer, 0-100%) and Reset.
jvalencia
Postby A_Camera » Thu Sep 20, 2018 11:42 am
jvalencia wrote:I gave modbus another chance and now it's working. Last time I had problems with it but for now it works.
Cool. What's in the box? Arduino...?
