CM-111
CM-111
Postby antomost » Sat Jul 21, 2018 2:03 pm
Hello,
I use the CM-111 from CNCMANIA with MACH3.
Now, i purchase UCCNC and UC400ETH.
Is it possible to use it?
It is a keyboard simulator and there is a .set file for mach.
Thank you in advance
Antonis
antomost
Re: CM-111
Postby cncdrive » Sat Jul 21, 2018 3:06 pm
If I understand it correctly this device emulates keyboard key presses in Windows?
If it works like that then it will work with the UCCNC too.
The best way to know if it will work is to check it out. :)
I mean, you can install the UCCNC software and you can test it in demo mode.
Simply configure the hotkeys in the UCCNC and test if it works with the device.
Users browsing this forum: Google [Bot] and 2 guests
