Axis Calibration
Axis Calibration
Postby naijin » Thu Jun 14, 2018 10:16 am
Hi there, this morning I decided to calibrate the axis on my machine, I went into configuration screen, selected Y axis, clicked Calibration, entered -200 and clicked OK, the axis started to move in the -Y direction but it was ever so slow ( I looked out the window and the grass on my lawn was growing faster than the speed the axis was moving at) this happened for all three axis, I tried adjusting the jog speed but it made no difference, have I missed a setting or something, or is there some way of speeding up the process? I have attached the xml file
Nick
Jade.doc
(31.81 KiB) Downloaded 496 times
naijin
Re: Axis Calibration
Postby cncdrive » Thu Jun 14, 2018 10:20 am
You can set the calibration feedrate on the calibration window, there is a Feedrate textbox on it.
Postby naijin » Thu Jun 14, 2018 10:32 am
Thanks cncdrive I tried setting it to 100 but it didn't seem to make great deal of difference, what should I set it at?
Nick
naijin
Postby cncdrive » Thu Jun 14, 2018 11:20 am
It works fine here. Attached is printscreen with the setting marked with red oval.
Postby cncdrive » Thu Jun 14, 2018 11:22 am
And one thing which can limit the calibration feedrate is if the axis velocity setting is set lower then ofcourse that will be the limit.
So, for example you set the calibration feedrate to 100, but the axis velocity is only 50 then the axis will run with 50 only.
Postby naijin » Sun Jun 17, 2018 2:02 am
Thanks for that cncdrive, it works great was able to calibrate all axis successfully.
Nick :D :D
naijin
