After upgrading to 1.2024 I wanted to try PCB milling with the Auto leveler plugin. So I changed the probe settings and M31 to use the engraving bit as probe. After loading the file and setting up the plugin I started the probing cycle. But after two or three probe steps I got the error message "The probe sensor was active. The operation was aborted". I double checked my wiring and also tested the operation in the status monitor. Everything works as expected. Do you have any idea/hint where this error message comes from?
My configuration:
Hardware: UC100+Stepcraft
Software: Eagle 7.6 + pcb-gcode-3.6.2.4 + UCCNC 1.2024 + AutoLevelerCA 1.0021
Thanks, Matthias
