But there is no real corner between an arc and line connected like that.
My collegue got back and we studied this issue and got to a conclusion that it has to work how it works now.
When I do 3D work my cam program writes everything as line segments. Even a perfect arc. I have noticed that even with lookahead set at 300 or more there is a noticeable speedup and slowdown as UCCNC processes each line segment. If I convert the same line segments to arcs in the cam program it is one fluid motion. I use a .001" tolerance in the CAM program so the line segments are pretty short.
I'm running in CV mode.
I normally convert to arcs as much as possible but I would like to get the same smooth motion with line segments if possible. Not sure if it is a settings issue or a CPU issue or if "that is just how it is" issue.
Derek
Why can't the Y axis start accelerating earlier, rounding the corner. As long as the rounded corner does not exceed the error tolerance, this would be the desired result. The higher the error tolerance, the sooner the Y can accelerate, keeping the speed higher.
cncdrive wrote:Gerry, yes, it is already doing that, but if the acceleration of the axis is not high enough then it will still not be able to accelerate up in time even if the path is modified/optimised like that.
