buttons to turn on the output when the machine is running
Re: buttons to turn on the output when the machine is runnin
Postby fixebr » Tue Jan 25, 2022 3:38 pm
dezsoe, спасибо вам за плагин, это именно то, что нужно!
Может быть, я со временем сделаю ему интерфейс, так как хотел в будущем разобраться с написанием плагинов)
fixebr
Postby fixebr » Wed Jan 26, 2022 1:05 pm
Sorry, I seem to forget to turn on the translator in the past message)))
dezsoe, thank you for the plugin, it's exactly what you need!
Maybe I will eventually make him an interface, because I wanted to deal with the writing of plugins in the future)
But I ran into a challenge of accidentally off. My 2 buttons are the inclusion of a vacuum cleaner and a vacuum pump/table, the vacuum cleaner must be able to enable during the execution of GCODE (that your plugin is just doing), and the vacuum pump is the opposite, should be blocked during milling (so that you accidentally do not release the item).
Also, in the future, I plan to put a vacuum sensor to pass the part of the E-STOP event.
So initially I wanted to make a macro, above me advised to make Macroloop. I tried to explore the code in your project plugin and use it in Macroloop, but unfortunately it did not work.
Tell me, is it possible to realize your plugin functionality in the form of macroloup?
I do not ask the fully finished decision, but I want to learn how to do similar tricks myself, so I need just an example code :D
Thanks in advance.
fixebr
Postby Daywalker » Wed Feb 02, 2022 3:33 pm
Hello dezsoe,
Thanks for the plugin, that's exactly what I was looking for for my suction.
I have now inserted and activated the plugin in UCCNC, I have also added the SwitchOutput data (see below) to my profile.
Unfortunately, I can't get the plugin to run.
I created a button on the screen with the button number: 20417, my macro also has the number 20417 and is structured like that of "fixebr".
Somewhere I seem to have an error in my mind, which still doesn't work in the process (i.e. with the G-code running) of the button.
Must say that I tested it in advance on the laptop in demo mode.
[SwitchOutput]
Button1=20417,3,7,False
bool buttonstate = AS3.Getbuttonstate(20417);                   // Get Button State
int bnum = 20417;                                           // Button Number
int Port =3;                                              // Port Number 3
int Pin1 =7;                                              // Pin 3 -> Suction
if(buttonstate)
exec.Clroutpin(Port, Pin1) ;                                  // Absaugung AN
AS3.Switchbutton(false, 20417);
exec.Wait(100);
else
exec.Setoutpin(Port, Pin1) ;
AS3.Switchbutton(true, 20417);                                 // Absaugung Aus
exec.Wait(100);
while (exec.IsMoving()) {} // Wait for exec.Code to finish
Thanks and Regards from Germany
Udo
(UC300ETH & UB1)
[Yeah, I use a Translator ;-) ]
Daywalker
Postby fixebr » Thu Feb 03, 2022 12:32 am
Daywalker wrote:I created a button on the screen with the button number: 20417, my macro also has the number 20417 and is structured like that of "fixebr".
Hey!
If you use the plugin from Dezsoe, then you do not need additional macros. Make a button number more than 22000 (then the button itself will not run any macro), and the plug-in tracks down to it automatically using the string from the profile file.
fixebr
