AXIS MOVEMENT
AXIS MOVEMENT
Postby MVPAWARDS » Thu Aug 01, 2024 6:25 pm
I setup axis movement but nothing moves unless I go into the jogging screen and type in a number, when I close the UCCNC program and restart it the jogging is back to 0, any suggestions? This is my first time using UCCNC.
MVPAWARDS
Re: AXIS MOVEMENT
Postby MVPAWARDS » Sat Aug 03, 2024 8:05 pm
OK Problem was fixed.
The gantry movement was fixed, however when a gcode file is loaded and ran, gantry movement is very slow
MVPAWARDS
Re: AXIS MOVEMENT
Postby Battwell » Tue Aug 06, 2024 11:56 am
g code gives a feed rate
eg f1000 for 1m/minute
if you dont have a feedrate in gcode the control will run at minimum speed.
you can also change the feedrate speed manually on screen by typing into the feedrate field and pressing enter.
Re: AXIS MOVEMENT
Postby MVPAWARDS » Thu Aug 08, 2024 12:04 am
Where is the Feedrate field?
MVPAWARDS
Users browsing this forum: No registered users and 34 guests
