Experimenting a little with my settings in EstlCam and I'm using the very latest version of UCCNC. When running a program I noticed UCCNC was using I and J movement commands. Between G02/G03 and I/J commands, I dont really understand the difference except I think that one breaks arcs up into tiny little straight line segments whereas the other moves in arcs. Wouldnt the I-J commands result in smother machine operation and smaller G code files? Anyway I attached a pic of the setup CNC controller set up screen in EstlCam showing the check box's. Which settings should I check?
I've experimented with this setting before but as I recall UCCNC didnt interpret one setting correctly so I've been running it with I /J box checked. Anyway, how does UCCNC handle arc commands and since it now seems I can use either setting, which is best?
