probing wrong direction
Re: probing wrong direction
Postby ger21 » Sun Dec 16, 2018 5:28 pm
The video is too short to really see what is happening.
Does it back off and do the second probe, or crash after the first one?
It looks like it's backing away after crashing?
Do both the X+, X-, Y+ and Y- all do the same thing?
Is this repeatable, or random?
My suggestion would be to add a message box to display the retract position before the retract move, and see what it is. Then maybe we can figure out why it's not correct?
Postby trendsetter » Sun Dec 16, 2018 11:15 pm
Hi Gerri,
yes it is repeatable and for x abd y the same. Tried to avoid Z. It is happening after first touch. Maybe I should try delays to find out the exact step
Br
trendsetter
Postby ger21 » Sun Dec 16, 2018 11:23 pm
And you didn't edit the macros at all?
There are a few hundred people using the 2017 screen, and nobody else has reported any issues.
You said it used to work fine? But then it started doing this? Something must have changed???
Postby trendsetter » Sat Dec 22, 2018 8:51 am
Hi all,
sorry for the delayed answer. As in 99%, thw error sits in front of the monitor.
Seems I edited the wrong line in the text file, I introduced by accident a probe diameter.
This let to an offset and the wrong direction.
Macros are fine.
Thanks to all!
BR Michael
trendsetter
Postby ger21 » Sat Dec 22, 2018 12:26 pm
Thanks for the follow up.
Everyone makes mistakes sooner or later. :D
