tool height probe diving after back off
Postby thegreatwaldo » Sun Dec 17, 2017 9:58 pm
Hi Balasz
I'm not sure what is happening with my tool height probe. When I press probe the z axis moves down touches the sensor pulls back a little bit comes down again , stops very shortly and then continues down about 27 mm and stops. Any idea what might be wrong ?
Cheers
Andrew
thegreatwaldo
Re: tool height probe diving after back off
Postby cncdrive » Mon Dec 18, 2017 1:44 am
The probe button calls the M31 macro. The macro is coded in the M31 macro file in the UCCNC/Profiles/Macro_Yourprofilename/M31.txt.
Open the probing macro with a text editor and you can then edit the macro freely.
Everything about the probing button action is coded in that macro like if it makes a single or dual probing movement, the probing feedrates, the retract distance etc.
Postby thegreatwaldo » Mon Dec 18, 2017 8:32 am
Hi Balazs
Thanks for that I will check that out.
Andrew
thegreatwaldo
Postby Battwell » Tue Dec 19, 2017 10:28 am
i had something like this when i re wrote my original probing code.
i fixed it by making all moves after the first downwards probe move incremental (g91) controlled then by + or - values to the movements
this ensured it could only go the correct direction
never a problem since
a nice touch was to add a "system beep" just after probing- so i knew it had hit the probe
Uc300eth on router and mill
Postby dezsoe » Tue Dec 19, 2017 12:07 pm
Battwell wrote:a nice touch was to add a "system beep" just after probing- so i knew it had hit the probe
I attached a small buzzer on the probe input. It's very useful! :)
