not a bug but problem
Postby baharg » Fri Oct 20, 2017 5:23 am
I have UCCNC + UC400ETH that work fine, how ever in the last 3 days when I load file from the USB flash disk the UCCNC disconnect from the controller. this dont done every time but it does a lot.
Please Help ?
baharg
Re: not a bug but problem
Postby cncdrive » Fri Oct 20, 2017 12:01 pm
It is basicly not adviced to load g-codes from external drive, but to copy the file to a local disk and load it that way.
When you load the file from the external USB drive does the blue LED blinks (goes off for some time)?
If so then the issue is probably that your computer is too "weak" or a drivers issue of the USB flash drive.
You can try to use a different USB flahs drive and you can try to reinstall the USB drivers for the flash drive and you can try a different, more powerful computer.
