TOOL CHANGER STEPCRAFt 840. D2
Postby EPacheco » Mon Apr 14, 2025 11:26 pm
Hello Every one, im having an small problem using the ATC from stepcraft. i thiks is a Bug from Macro 20206. when i change the current tool using the release button on UCCNC it opens the ATC and keep opening making a Rattling soundon the Switch Box. until i press the button again to close, its not a nromal behaivor.
any suggestion will be highly appreciated.
Best,
Esteban
EPacheco
Re: TOOL CHANGER STEPCRAFt 840. D2
Postby cncdrive » Tue Apr 15, 2025 8:11 pm
It would be good to know how that ATC exactly works and then see the macro file.
You can open the macro file with a text editor and could follow through the logic to see if it requires any code change the fix the mentioned issue. (If it can be fixed, I'm not sure as I don't know your ATC in details yet.)
Users browsing this forum: Google [Bot] and 8 guests
