Cannot change screenset
Postby DavidR8 » Thu Apr 10, 2025 4:03 am
Running 1.2113.
Tried to change to the default screenset.
Selected it and the preview appeared but nothing else happened. I understood that UCCNC would restart on selecting a different screenset.
Couldn't find any documentation to troubleshoot.
DavidR8
Re: Cannot change screenset
Postby cncdrive » Fri Apr 11, 2025 12:30 am
You can check the profile file in the UCCNC/Profiles folder and check what screenset is defined in there.
Postby DavidR8 » Fri Apr 11, 2025 1:22 am
cncdrive wrote:You can check the profile file in the UCCNC/Profiles folder and check what screenset is defined in there.
I was able to check the .pro file and change it to what I wanted but isn’t the functionality supposed to support changing from the screenset dialog box?
DavidR8
Postby cncdrive » Fri Apr 11, 2025 11:52 am
Yes, it works here, however the method of changing screenset was changed after 1.2115 if I recall.
I tested it with 1.2118 and it worked fine here.
Postby DavidR8 » Sat Apr 12, 2025 11:08 pm
What is the new process to change screenset?
DavidR8
Postby cncdrive » Sun Apr 13, 2025 1:23 am
There was an issue that it sometimes started too early before the motion controller could connect, also the reboot process was changed a bit.
