(Screen Edit) - LED 142
Hello guys,
There is a bug with the LED 142 (and other axis-enable LEDs).
It works only with the RESET mode. But it doesn't correlate with an actual setting of "Axis Enabled" in the setting menu.
For example: if I disable axis A in the setting menu, and machine is not in the RESET mode, it shows me that axis is ENABLED.
With my understanding it shouldn't happen - if you disabling axis in the settings, it should always show disabled LED state no matter if machine is in RESET mode or not.
Basically this LED right now works as RESET led.
I have an automatic dust-shoe (axis A), but I need to enable or disable it sometimes. It's not a problem via the settings menu, but I need to have an indication on the screen to see its state.
Cheers!
Cheers!
