Probing bug with XHC-HB04 Pendant
Posted: Sat Jan 21, 2017 10:43 pm
I have a problem with the XHC-HB04 pendant plugin. When the MPG mode is selected, the probing doesn't work all times. UCCNC thinks the probe was activated when it wasn't and gives a error message.
To get the probing working I edited the probing makro M31 and switch to Continuous mode before probing and back to MPG mode at the end.
Now I want to use the autolever plugin, and I always have to manually switch to Continuous mode or it won't work.
When I forget to switch to Continuous Mode before starting the autolever code and get the error message, I have to shut down and restart UCCNC.
If it is not possible to find the problem with the XHC-HB04 pendant plugin, is there a way to run a makro before the G-Code is executed (after pressing Cycle Start or Run at the pendant)? I only found makro M30 which runs after the G-Code was executed.
Many Thanks,
Magnus
Many Thanks,
Magnus
