probing isnt working
Postby danielchindea » Thu Apr 09, 2020 6:01 pm
Hello,
I am new to uccnc. Just bought the axbb-e.
Everything runs smoothly except probing. I cannot make probing to work as expected, either using the default macro button or probing plugin.
If I home the machine and probe using a simple touch probe, it works. If I hit probing again it works. If I move the Z axis then it's not working as it should. It comes down by a random amount and turns back+ retract. I cannot use it at all like this.
What should I do? Actual probe (hardware) is working ok. I've checked it using the debug plugin and it triggers when it should. It drives me completely nuts as I have work to do.
Thank you,
Daniel
woodbe.pro
(42.44 KiB) Downloaded 580 times
danielchindea
Re: probing isnt working
Postby danielchindea » Fri Apr 10, 2020 7:04 am
Either of the two MDI commands works erratically, moving down from 2 to 20mm with apparently no logic.
No false probing is happening as I monitor the pin.
G90 G31 Z-100 F200
G91 G31 Z-100 F200
Any ideas?
danielchindea
Postby danielchindea » Fri Apr 10, 2020 7:15 am
Got it to work. No fault on UCCNC.
I reversed the wires going to my touch probe (clamp and plate). Although I cannot meter any voltage or continuity between any of them and the spindle house. Do you have any explanation for this?
Thank you,
Daniel
danielchindea
