Ver. 1.2019 - M30 not work from G-Code
Postby vitber » Fri Mar 08, 2019 9:30 am
I am testing version 1.2109.
After running GCode "M30"-Command will not be executed.
Only if entered in MDI.
In version 1.2049 is correct.
vitber
Re: Ver. 1.2019 - M30 not work from G-Code
Postby cncdrive » Fri Mar 08, 2019 9:42 am
I have checked and you are right. I mean the M30 program end end rewind function works fine, but the M30 custom macro file does not execute in version 1.2109.
I have checked the UCCNC associated code and the issue is there, I have made the correction, it will work in the next release.
Postby vitber » Fri Mar 08, 2019 9:46 am
Thank you very much
vitber
