Close file button issue.
Postby kig23 » Sat Mar 31, 2018 7:19 am
When you open UCCNC and then press the Closefile button without loading a G-code file in the Toolpathviewer you will see the writing "Loading file" and the loading bar for a while, and in the Codeviewer you'll see a red and white writing "Closed". I'm using UCCNC version 1.2047.
kig23
Re: Close file button issue.
Postby dezsoe » Sat Mar 31, 2018 5:44 pm
In short: yes.
In longer: all versions of UCCNC do the same. I think you have a computer slow enough, if you have time to see this and read all text. :) Anytime you close a file this happens. UCCNC loads the file Empty.txt in the Contents folder. (Check Diagnostics tab after Close is pressed.) There's no bug, UCCNC works this way.
Postby kig23 » Sat Mar 31, 2018 6:00 pm
Thank you.
kig23
