Grey wrote:I am using UCCNC with the UCR201 pendant. I am using the AXBB-E board.
When I move the spindle with the pendant and then wait until the pendant screen goes black and interrupt it with any button, the spindle rapidly moves a few inches. This is completely repeatable and you just need to time the waking up of the pendant correctly. Just after the screen goes black. You also need to move the spindle initially. Occurs in both velocity and step mode.
I have tried UCCNC 1.2113, 1.2115, 1.2117 and all contain the bug.
I see several references to this bug on this forum including a video demostrating it. Is there any known fix or work-around?
The bug is obviously annoying as it is difficult to avoid and will damage the workpiece and/or break the end mill.
You are absolutely right.
Today I was vacuum cleaning the table and I noticed the Y axis moved forward, then backward a couple of millimeters. I thought that's not that bad, it must be the usual pendant bug. Then OMFG, somehow UCCNC received a cycle start!
This was scary as hell because the spindle turned on and the machine moved toward me at full speed!
How can this be possible?
I'll probably test the 1.2118 next, but right now I think the pendant is a safety hazard.
