Slave axis unslave after homing.
Re: Slave axis unslave after homing.
Postby cncdrive » Wed Sep 27, 2017 8:41 am
Hi Andrew,
Thanks for the explanation.
Could you please also post the profile file of the machine?
Postby shad » Wed Sep 27, 2017 12:23 pm
Balazs, this is a profile file.
NeuronPlasma.pro
(32.64 KiB) Downloaded 735 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby cncdrive » Sat Sep 30, 2017 10:24 pm
This issue was now fixed in version 1.2045: viewtopic.php?f=2&t=240&start=40
Postby manny » Mon Mar 25, 2024 2:06 pm
Im having the same issue, did you ever solve this ?
manny
Postby cncdrive » Mon Mar 25, 2024 4:32 pm
This was solved in earlier versions, so it is strange that it happens to you in 1.2116.
We will test it soon.
Postby manny » Tue Mar 26, 2024 2:33 pm
cncdrive wrote:This was solved in earlier versions, so it is strange that it happens to you in 1.2116.
Is there a way to open uccnc in Debug mode to show if its get unslaved or what happens ?
manny
Postby valhallaCNC » Tue Mar 26, 2024 10:20 pm
I currently run 1.2113 , have hard limit switches. I park my machine left corner with z up. I use soft limits as well. I never used limit switches as home switches. I decided to use the switches as homing switches also. Everything was configured with the correct port and pin. Homing worked fine. I next configured a .5 back off. My A is slaved to Y. The Y and A axis started the back off, Y stopped properly A continued moving tripped Y drive overload, was still moving when I hit E- Stop don't know how far it would have went. I restored everything back to original . Only tried this once it was enough, had to re-square gantry.
valhallaCNC
Postby manny » Thu Mar 28, 2024 9:29 am
valhallaCNC wrote:I currently run 1.2113 , have hard limit switches. I park my machine left corner with z up. I use soft limits as well. I never used limit switches as home switches. I decided to use the switches as homing switches also. Everything was configured with the correct port and pin. Homing worked fine. I next configured a .5 back off. My A is slaved to Y. The Y and A axis started the back off, Y stopped properly A continued moving tripped Y drive overload, was still moving when I hit E- Stop don't know how far it would have went. I restored everything back to original . Only tried this once it was enough, had to re-square gantry.
I'm note sure how this is related to this issue ?
manny
