RS485 for VFD controla and Mach 3
Posted:
Wed May 22, 2024 11:53 pm
by gills
Hey guys, I am setting my first cnc mill and I am using just two axis X and Z. I didn't really want to invest in another AXBB-E controller, but I have an older DB25 basic BOB and a UC100 not being used. I can control everything through my BOB except for the VFD spindle. I have been researching the USB RS485 and feel confident on the install and files. My question is, once it is installed and up and running and I load a cut program into Mach 3, will Mach automatically turn the spindle on like it normally does with my AXBB-E or do I have to manually turn it on and off through the Mach 3 screen? I appreciate any experienced opinions out there.
Re: RS485 for VFD controla and Mach 3
Posted:
Thu May 23, 2024 11:06 am
by ger21
With Mach3, you'd need to use Modbus to control the VFD with RS-485. When set up correctly, yes, it will turn it on and off with M3 and M5 g-codes.
Posted:
Sat May 25, 2024 6:19 am
by gilles974
bonjour
c'est un sujet qui m'intéresse fortement, j'ai jamais trouvé de docs sur modbus. est ce que cela existe ??
suivre bêtement un tuto sans en comprendre un minimum c'est nul
salut
gilles
Posted:
Sat May 25, 2024 6:12 pm
by charliem
bonjour
Il y a une tonne d'informations sur le Web si vous effectuez une recherche.
https://www.homanndesigns.com/pdfs/Using_Modbus_with_Mach3.pdf
