Issues loadingAXBB ethernet on my laptop
Postby gills » Sun Jun 04, 2023 7:26 pm
I have a new Windows 10 64 bit laptop that I plan on dedicating to just the cnc machine. I was going through the AXBB ethernet setup and I can not get the util.exe file to run. Going through the UCCNC instructions I captured screen shots of most of the critical steps. I have them in order from 1 to 5. Can you anyone look at these and help figure out where I am stuck at??
Thank you
gills
Re: Issues loadingAXBB ethernet on my laptop
Postby cncdrive » Sun Jun 04, 2023 8:08 pm
You mean the UCx00 utlity tool exe file is not even starting? Or ... ?
Postby gills » Sun Jun 04, 2023 9:20 pm
cncdrive wrote:You mean the UCx00 utlity tool exe file is not even starting? Or ... ?
I have been able to download the .dll plugin files and thats it.
gills
Postby gills » Sun Jun 04, 2023 10:01 pm
Here is the part and file that isn't working from section 5.2 of the manual. The UCxxx_utility I had to copy it on a jump drive from my desktop and load it on my laptop. When I manually started it and the UC xxx utility V1.6 window opens up, the same one in the attached pic, I hit the scan button and nothing happens.
gills
Postby cncdrive » Mon Jun 05, 2023 11:20 pm
So if I understand you correctly the utility software runs but the device scan with it does not give any results?
You do not even get a no device found text?
Postby gills » Tue Jun 06, 2023 2:31 am
Yes Sir, correct I don't get any message just the blank screen as in the screenshot above.
gills
Postby cncdrive » Tue Jun 06, 2023 8:43 pm
That is very strange, I've never seen that and currently I don't see what could cause it.
I mean if nothing is found in the scanning process then still there should be a message stating that no controller was found.
Postby gills » Tue Jun 06, 2023 8:50 pm
I am going to remove the files from my computer and redo the setup and see if I get a different result. So I need to download the setup file before I setup the adv network correct?
gills
Postby cncdrive » Wed Jun 07, 2023 1:52 am
Oh, wait, I just realised that you using the utility tool 1.6 , but the AXBB-E was released with the utility tool 1.8., so you need that or newer version to work with the AXBB-E.
Please download the latest UCCNC software and the utility tool in it is version 1.8. and that will work with your AXBB-E.
Postby gills » Wed Jun 07, 2023 2:56 am
That was it my Friend! Absolutely wonderful! I am connected to MAch 3 and have my two green steady lights and my blue light. Thank you Sir!
gills
Return to Mach3/4 Discussions
